09-25-2018, 01:50 PM | #1 |
Hensim 110 quad clutch adjustment
I have a hensim 110 automatic 3 speed quad. The clutch is starting to slip. It needs to rev high RPMs before it slowly ingauges and moves. Once moving it seems to reach up to speed. There is a shaft and lock nut on the outside of the clutch case. after researching online I've noticed it most of those have a slot on the shaft that you can turn after loosening the lock nut around it. This particular model does not have a slot on the shaft. It seems to have a washer. Maybe even a couple or on it but one seems to have wore out. Wondering how to adjust the clutch to make it tighter with the washers spacing. Any help on this would be much appreciated.
09-25-2018, 03:17 PM | #2 |
Is this a full auto bike ,as in no shift lever or is there a lever and it’s semi auto ?
09-25-2018, 05:18 PM | #3 |
I don't believe you can adjust that style clutch, it is a centrifugal-type like ones used on go-karts and minibikes with a lawnmower engine. The link below might be a replacement for the one you have, read the specs and compare.
https://www.vmcchineseparts.com/coll...uto-version-19 |
09-26-2018, 11:36 AM | #4 |
clutch
yES THIS HAS 3 SHOES IN IT,,, you have to take it apart,.. the tool is the easy way to undo the nut... but check youtube video ... some one has it there with no tool needed,,, can buy them every where... ebay.. amazon chinses parts places near you..
110 automatic clutch |
