07-27-2019, 10:38 AM | #1 |
Mikuni carb leaking gas on Apollo rx250
I’m having a problem with leaking gas ride on the stock carb for over a year and few weeks ago it’s started leaking gas from the hose at the bottom of the carb I installed a new carb thinking it would fix it because I heard about float pins getting stuck but I installed it and on the first start up with the new carb it was still leaking gas anyone know what the problem can be ?
07-28-2019, 08:17 AM | #2 |
The petcock and/or the fuel line.
07-29-2019, 01:51 AM | #3 |
tap on the side of the carb with a wrench or something made of metal repeatedly and it should set the needle valve in place, make sure bleeder screw is tight at bottom of carb as well.
