07-12-2022, 12:51 AM | #1 |
Thinking about a X-Pro Templar..
I read that 20+ page about the Templar and then realized a lot of the posts were about the Templar X, which seems to be discontinued. The search function won't work for me on the site on mobile, so hopefully this hasn't been asked before but.. what are the main differences between the X and the regular one?
I was considering the Apollo 250 but then saw the Templar had the lights and most of the stuff required to title and register it. This will be my first bike ever, and I've seen all the comments about upgrading/changing diff things like the carb and sprockets etc Really just want to make sure the Templar (non X model) can be upgraded/tuned just like the X. Mostly looking to add HP so that it can go faster for road speeds, although I do plan to use it on trails most of the time, but I live in a rural area where 55 mph streets are common and I don't wanna top out right at the speed limit. Edit: somehow in the last 4 hours the Templar was taken off Amazon, which is where I planned on buying. Now kinda lost and might just do the Apollo. I guess technically I'd have the same questions about the Apollo for upgrading. 2nd edit: Templar is on powersportsmax so I could still do that . Original questions/concerns stand. Last edited by riddlerap; 07-12-2022 at 01:32 AM. |
07-12-2022, 07:13 AM | #2 |
The only real difference is the suspension, the Templar X comes with fully adjustable forks and Shock, the Templar comes with only pre-load adjustment on the Shock, and no adjustment on the forks.....but still has upside down forks.
07-12-2022, 07:25 AM | #3 |
Standard Templar 250 still has the same engine as the X. It also has the folding short shifter, bear claw foot pegs, beefy swingarm with heavy duty axel adjusters, much heavier spokes and heavier cast alloy hubs than you will find on any of the dual sports, roller style throttle, and unlike the X, the frame is not black (painted color lime green, red, orange, blue, etc or whatever the options are available)
What's missing? Well the inverted front forks are not adjustable like they are on the X (preload only, not damping). Rear shock also not adjustable. Standard Templar does get a stainless steel exhaust system, but no luggage rack.. I can't tell if there are adjustable levers that did come on my X (photos just don't show that). The engine guard is also missing, and I think the carb is not polished (smoothbore on the X). I think that's all of the differences- it does have the kill switch. I have been impressed with build quality of Templar X. Welds are excellent, and components are definitely above average. I don't know if Zuumav has ever imported anything to US market before these two bikes, but the build quality demonstrates that Zuumav has been building enduros for racing for years. They know how to build excellent frames. There are mounts for twin radiators on my frame, so this frame probably gets a 300 cc liquid cooled engine in other markets. It is clearly strong enough to handle that power. I will probably eventually do that! Last edited by Thumper; 07-12-2022 at 08:53 AM. |
07-12-2022, 07:39 AM | #4 |
Templar is a completely different frame measuring 6 inch's shorter wheelbase. Not sure of manufacturer. TemplarX has similar frame as Kayo T4, TM38 EGL A16 etc. Leaving more room for engine upgrades and cargo space.
07-12-2022, 08:07 AM | #5 | |
I am going to contact PowersportsMax and ask if they are planning another lot of the X model. But as of right now, July 12th they are still listing the standard Templar for $1599 ($300 shipping, I think). Gone from Amazon, but it is cheaper directly from Powersportsmax anyway. |
07-12-2022, 08:55 AM | #6 |
I'll probably be taking the plunge on one today, so when it gets here, I could update every one. I saw someone on YouTube say that Henner sells a custom suspension set for the Templar, so long term I could buy that maybe. I wonder how much the size/space difference would make on being able to modify. I saw Henners big bore engine upgrade, I can't tell if it's for the X or both.
07-12-2022, 08:59 AM | #7 |
Would anyone recommend the Apollo over the Templar since I can't get the X version? How easy would adding lights and mirrors be to a bike? The Apollo has a bigger wheelbase, so I don't know if that would make it better for modifications and whatnot
07-12-2022, 09:22 AM | #8 |
I like the engine on the Templar (ZS172FMM), and the Templar frame appears a bit more substantial. But the extra length of the frame on the Apollo might be good. The Templar comes with a 520 chain/sprockets. Can't tell with the Apollo.
07-12-2022, 09:31 AM | #9 |
Being so new to this thing, I just have no idea which to go with! I'm leaning Templar. One thing I found weird is that the Apollo claims 70+ mph whereas Templar claims only 60+ out of the box. Both seem to be solid, I just hope I'm not screwing myself long-term by getting a bike I can't upgrade.
07-12-2022, 09:50 AM | #10 | |
Personally I like that low gearing for off road riding, but a 42 or 39T rear sprocket will increase top speed, and the 172FMM engine has plenty of power to go 70mpg. Replacing the rear sprocket is not a difficult job. And you will need a chain break to shorten the chain. That's also pretty easy. People change sprockets and discuss it on the forum all the time. |
07-12-2022, 09:59 AM | #11 |
I don't know what kind of money you have to spend but if you are looking for something right out the box that can run 75+ mph you might want to look at the Lifan KPX 250. It's has a 250cc engine that puts out 20 hp and has a 6 speed transmission. It is also fuel injected and street legal so there is no issue on getting ir registered and tagged unless you are in California. It also has a full 2 year 12,000 mile warranty with excellent after sales support. well worth the extra money. No need to change sprockets or worry about tuning a carb. Right now i think Venom Motorsports is about the only place that are selling them. Venom is also a excellent dealer to deal with. I just picked one up a few weeks ago. https://www.venommotorsportsusa.com/...d-street-legal
07-12-2022, 10:19 AM | #12 | |
I'm about 99% all in on the Templar, so I will keep people posted when I get it and learn more about the parts and everything! |
07-12-2022, 10:19 AM | #13 | |
07-12-2022, 10:45 AM | #14 | |
For anyone who did buy a Templar X, what was the cost? If it's hundreds more than the Templar, I might just take their Prime Day sale price today. |
