Caleb had his first play on the new toy 2day...
Didn't take him long to get to grips with a manual clutch.. now it's just rideing time..
It went well... Apart from every now and then the chain
would jump a few teeth on the front sprocket... played with chain tension
but did help.... I took the side cover off.... The 13 tooth front sprocket
is to small .. the 2 retaining bolts are 2 close to the teeth & the chain rides on
them lifting it of the sprocket letting it slip..
So have ordered a 15 tooth front & 48 tooth rear... Should put the gearing just slightly lower
than the 13/41 it has by 1 tooth...
got to shorten the stand..to long , the bike keeps falling over...
And its dam hard motor to find nutural in... hopeing that will sort it self as the
gear box losens up... He's only realy used 1st gear so far..
We will get this little chinese shitter sorted... Motor goes real well .. took 3 kicks
to get it started from new...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
KIWI BIKER FORUM......
http://www.kiwibiker.co.nz/forums/content.php
http://www.remotemoto.com/
E-mail...
xtpete1@gmail.com
