Old 08-27-2010, 09:32 PM   #31
TurboT   TurboT is offline
Originally Posted by FosterVS
Originally Posted by waynev
Good point, they do call it a mikuni carb, not a mikuni "type" carb. Make sure you also replace your spark plug with a true NGK.
Already changed the plug - tip for others, NAPA has these in stock, and cheap.
Also, the intake on these Rebel T3 quads is already 30mm, so a 30mm carb will bolt right on.
I get my plugs from Lorcdo out west here, also cheap. Always have them if you know the plug number.
