11 HP Track Drive Snow Blower
I am having trouble with a new 11 HP track drive snow blower.
Can someone tell me how the low oil pressure sensor is supposed to work. When the engine is up to RPM the sensor (yellow wire) still measures open to ground. Also, is there any information on the module (has a yellow and black wire) that allows the ignition system to get voltage while there is no oil pressure? This module is intermittent, so to make the engine work reliably the module has to be bypassed (bypass button out).
