Old 05-13-2024, 07:27 PM   #6
Your rear shock:
Eye-to-Eye Length: 465mm (this is not a size that seems to exist, but 460 and 470 do)
Travel: Around 70mm before hitting the bump stop
Mounting Bolt Diameter: 10mm
Shackle Width: 24mm (both top and bottom)
Spring Cross Sectional Diameter: 11.66mm
Spring Coil Outer Diameter: 72.25mm
Barrel Diameter: 45mm
Templar X
https://www.chinariders.net/showpost...4&postcount=45
You can buy this one for ~$160, shipped free (KKE is the manufacturer)
Eye-to-Eye Length: ~460mm
Upper bushing width: 22mm wide (new one comes with the shock
Upper and lower mounting bolts: M10-1.25 with locking nuts
Spring rating: 350 lbs/inch
Spring Coil Outer Diameter: 83mm
lower bushing width: 20mm
The spring coil diameter might be a clearance issue, but this is a fully adjustable shock (compression dampening, rebound dampening, preload). Check your clearance. It might fit. The top mount might need washers (2mm total). The lower mount? Well, it is 20mm arm to arm. That's a 4mm narrow compared to 24mm (shackle width). But might be workable depending on what you have on the linkage.
