Originally Posted by NYCDiesel
It backfires right before it starts decelerating so usually I'll be like maintaining 65mph and then it cuts out and while slowing down it backfires a little bit, I have to let off the throttle to get down to about 45ish and then can roll back on the throttle and it will be fine if I just hover around 50 but if I start pushing past that for more then 30 seconds or so it does what I stated above.
I'll try to get a video of it but of course its rain all day today.
Thumper, the airscrew is what the video I posted is referring too right? Thanks for the help guys, it gets annoying because I'll be going the speed of traffic at and then the bike just starts decelerating and I feel like an idiot because on my RR I just pass everyone lol.
Yes, Drill out that airscrew access block-off.
It sounds like you've gotten into these stock carbs with EPA mandated access restriction
Nibbi isn't better. In fact, they are essentially identical. This stuff is all cloned. The OEM carb is OK.
Here are a couple of links to work done on this carb. Jet kits and good photos.
https://www.chinariders.net/showpost...09&postcount=7
https://www.chinariders.net/showpost...3&postcount=25
