is it a doughy blugh stall (rich) or a scream pap then cut out (lean)?
Yes you can remove the tamper proof screws and then do normal rejetting on the stock carbs...
I'd be inclined to believe you elevation (less dense air) on stock jetting is probably rich and might need smaller jetting...
