Old 04-17-2024, 11:09 PM   #12
superjocko   superjocko is offline
Ran into a setback
I disassembled the steering head on my bike this evening only to find that the All Balls Racing part number 22-1021 tapered roller bearing kit is not a fit for my bike. Both the inner and outer diameters of the bearings included in that kit are much too large. I've sent the dimensions of the bearings and seals that I need to All Balls and will await their reply.
The OE ball bearing races on my bike measure as follows:
Upper, 22.5mm I.D, 41mm O.D.
Lower 24.0mm I.D, 41mm O.D.
Stay tuned.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come.
