About 95% finished with this. I located one countersink...poorly. And forgot one completely, even though I laid it out and center punched it. Getting old is not for wimps. it is back together just for grins. It will come back apart shortly. I finished degreasing everything that rides on the shaft and found that the bearings are good as are the outer races. The high speed drive pulley, though, needs some love. I need to open the bore to 7/8" and press in a 3/4" ID bushing to take out the slop. Maybe Friday.
In ankle news, it's all good. Per the bone doc, the fibula has healed perfectly. I can now start to put weight on it again. So, I've been spending some time using both feet with the crutches. Doing that, I've managed to get myself into, and out of, the pickup with no help. Same with the Jeep, but I'm not quite ready for the clutch. That's a bit hurty.
Per the doc, with PT, I should be out of the freakin' boot and in a matching pair of shoes in another 4 or 5 weeks.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
