Thread: Moto Cult
Old 03-25-2024, 01:24 PM   #43
Originally Posted by bigdano711 View Post
If not MotoCult, who? links?
This is the cam and followers, I ordered, but they ended up being free to me, because they didn't show up till way later, and I already was refunded my money. The cam gear didn't have a dot on it, but I just used the slot for the cam pin as reference, and made my own dot, it was only one tooth away from the slot for the pin. I got the 4degree key from a member on here. I am pretty sure the cam is a 292 grind.https://www.ebay.com/itm/174384704948
This is the 70mm (250cc) kit, I used, but it comes with a stock like head gasket though, and I wish I had the steel one.Just found this amazing item on AliExpress. Check it out!
$75.84 | 70mm Big Bore Cylinder Kit Cylinder Piston Set For CG250 TO 300 CG300 16mm pin 167FMM
https://a.aliexpress.com/_mMSYA6m
