Originally Posted by YakClimber78
After a bit of digging, I’ve noticed that the Templar X250 has similar specs as the Brozz. Is this a bike I should be looking into as well?
Thanks
Yak
Templar really is a completely different style of bike than the dual sports (Brozz, Storm, Hawk, etc). Templar X is an enduro with a flat seat, three or four inches higher off the ground, 5 more horse power (249cc with an OHC engine, not 223cc with a push rod engine), with a much tougher swingarm and an integrated cast axel slot. Braided SS brake lines (dual piston front caliper), cast alloy bearclaw footpegs...and more. And seating position is different. Even the rake on the front forks is steeper (more agile), and it has inverted forks and stronger triple clamps. Templar is much more motorcycle for the money.
