Old 01-03-2024, 02:47 PM   #2
rithac   rithac is offline
If you don't want those smoothbore carbs, pull one off and put it in a flat rate box to me before you put gas in it. I can pm you the address and payment.
The plan is to see how they do as is, and then if needed upgrade to the Nibbi. If they run as is, I won't be in any hurry to upgrade. Even if they are underpowered starting off, they will be fine for learning. I was mostly thinking of changing them out if they ran rough, so I'd have the ability to adjust the settings.
