Tom is dead on. Adjust those valves before you bother doing anything else. It is a wild card that you can't avoid. Until you know your valves are opening and closing completely and at the right time, you can't really troubleshoot.
Also, 120psi compression is easily enough for the engine to end pretty normal if it's the rings. But if it's the valves, it can stop running when it gets hotter
