Old 12-07-2023, 08:01 AM   #6
Originally Posted by Pharaoh View Post
I like you you be everywhere so what do you think about some type of throttle sensor or even a fuel pump failure I'm still going to adjust the valves nonetheless
EFI is not something you can't really diagnose without testing components. First you need a fully charged battery for the fuel pump, fuel injectors and ECU to work. Otherwise you are wasting your time. Check and make sure that you are getting full power to the fuel pump. If not, you have some sort of voltage issue, be it bad battery, bad ground or break in wire.
2020 Kawasaki Vulcan S
