Old 12-06-2023, 09:46 PM   #10
Originally Posted by Pharaoh View Post
Lol that's the first thing I did
I guess you mean you checked the kill switch. And that wasn't the issue??
The symptoms you describe, that it started but died when you twisted the throttle over and over, sounds like a throttle position sensor problem (EFI), but could be something else.
I don't know if you have a throttle position sensor on the EFI Hawk, but if it started fine, then died when you twisted the throttle, valves might be tight but that clearly wasn't the issue (but you still should set them). I have a TPS on my TDI diesel and my 1.4L turbo Jetta (gasser).
My interpretation- now that you clarified that it DID start, but died when you twisted the throttle repetitively, is that this is yet another mysterious EFI fail.
I am out of my wheelhouse here. Speak to the EFI wizards.
