Old 10-13-2023, 05:35 PM   #14
Templar X 250 Fuse: F10AL250V
F 10A L
F: Fast Blow
L: Low Over Current required to start blowing
10A: 10 Amps
250V: Can handle voltages up to 250 volts and still function as designed
Size Metric: 6x30mm
Size SAE: 1/4" x 1 1/4"
Example Domestic Supply (NAPA):
Fast Acting, Glass Tube, 1/4 x 1 1/4 (6.3 mm x 32 mm) Physical Size, Nickel Plated Brass Endcap Construction, UL Listed Product Meets Standard 248 14
Made in Taiwan vs Made in China
https://www.napaonline.com/en/p/BK_7822060
NAPA Fuse: BP/AGC-10-RP
BP: "Bolted Pigtail" type of fuse
AGC: All Glass C size Cartridge (1/4" x 1 1/4")
10: 10 Amp
RP: The "RP" in a fuse designation does not have a universally standardized meaning but may refer to a "rejection type" or "rejection pin" design, which is often used to ensure that fuses of the wrong amperage rating cannot be inserted into a circuit. R at the end usually means RoHS compliant, but there is nothing in the data sheets that mention what RP means.
Most AG fuses which are made for Automotive use have a Voltage Rating: 32V AC/DC
