Originally Posted by Jmeyers
I have the above bike and it will not start. It has a kick start FYI so it has no battery. I have drained gas, cleaned carb and still wont start. It will crank for a second when I add starter fluid to it but dies quickly there after. I am not sure what else to try. Any help would be greatly appreciated.
When you said you cleaned the carb, I thought you meant including the jets. But since you can't access the jets, very likely the pilot is clogged as dirtbkr188 said. Either get the bowl off via slotting the fasteners and replacing with regular screws, if this is possible, or get a new carb as was already recommended. If you keep that carb, also drill out the brass cover that seals in the air/fuel mixture screw.
And also BTW having kick start does not necessarily mean no battery.
