Old 07-14-2023, 02:22 PM   #6
zero_dgz   zero_dgz is offline
Helicoil for sure. The good news there is that the coil is steel, so it should be quite a lot harder to strip next time vs. the original aluminum.
If I were you I would run a rubber gasket on the head of the drain plug afterwards, too, since the Helicoil might not be 100% liquid tight.
