Old 03-05-2023, 02:11 PM   #11
clash 168cc   clash 168cc is offline
You need to use a feeler gauge and spark gap checker. They are not optional .Not where you should wing it. If you only get popping after that, could remotely be a sheared crank shaft key. Happened to me once on a boat motor. puts the timing totally off. Or your valves are leaking/corroded possibly. Take off the head and check gasket and valves.
