Old 12-22-2022, 08:54 AM   #31
Originally Posted by Fast_Freddy View Post
I'm cautiously optimistic about the new flasher relay. I really think they sent me the same signals you got from eBay. FWIW the headlamp bulb is an H6 and the oem unit appears well suited to a reflector housing.
I found mine at half turn out when I drilled it out. I dropped the pilot back to a #32. 35 was too rich on mine. I think I will try one turn out. I am glad it is easily adjusted from the side. Might need adjusting.
How many turns out do you suggest for the idle mixture screw? When I drilled the cap the bit hit the screw and may have turned it. IIRC the typical setting is 1.5 turns out but what are you running?
Reply got stuck in the quoted section. Can't seem to edit !
