Originally Posted by GaryF11
It can’t be installation error I’ve installed clutch cables plenty of times there is literally not enough inner cable to reach I’ve tried everything including taking the shift arm off and reinstalling with cable already attached and there just isn’t enough cable it’s about an inch too short even with both adjustments all the way in to give it as much slack as possible…
Is there a way to remove the clutch lever on the casing, change it's position (a splined lever install?). I don't own a Hawk. Maybe it just needs to be moved. Otherwise...
Pics, please. I believe you, but this doesn't make sense.
