Originally Posted by Thumper
It seems like you are repeating a systematic installation error. No offense, but clutch cables come with sufficient inner cable length for the sleeve length.
Take a picture of the installed cable at the lever, and at the clutch side on the case. At this point, we need to see this to help you.
It can’t be installation error I’ve installed clutch cables plenty of times there is literally not enough inner cable to reach I’ve tried everything including taking the shift arm off and reinstalling with cable already attached and there just isn’t enough cable it’s about an inch too short even with both adjustments all the way in to give it as much slack as possible…
