Old 11-02-2022, 10:57 AM   #2
Hmm.. never heard that before.. definitely worth the try, thanks for that info
Rim locks are for running at low air pressure while racing. They prevent the tires from spinning on the rim, which would shred the tube. Templar X is equipped as a raceable enduro. Those sprockets it comes with are made for running with close ratio choices below 40mph. It's really geared down 13/49 which makes sense for this setup.
It's also uncomfortably tall for most people. Same reason... Motocross/Enduro. Longer suspension travel and higher ground clearance. Even the tapered handlebars are flatter and wider than a dual sport. Templar is just a street legal Enduro.
