Originally Posted by clash 168cc
Mainly concerned about if the fuel injector, computer or display goes out. Where to get parts. Didn't know about the Honda version.
Are you saying the 161QMK motor uses the same engine parts (head, clutch, variator, rockers) as any GY6?
The GY6 is a pretty standardized design. It's quite likely that parts from any long case 61mm bore GY6 would fit. Being a Lifan, I wouldn't expect the engine to have any problems. EFI parts might be a problem right now but before long EFI scooters will be the norm rather than the exception.
The plastic should be the same as the Honda Click or Honda Vario which are popular in the Philippines and other countries.
