Old 06-06-2022, 08:47 PM   #4
Darkrider   Darkrider is offline
The hardest part is finding the right style of adapter for your bike in terms of alignment, but yeah they do make it easier. I am using a clamp on sprocket adapter secured to the rear hub. I keyed both surfaces and applied Loctite 638.
Took me a moment to understand what you meant there but i see now that there is an adapter that bolts to the hub itself then the sprocket bolts to that to make it a fixed mount instead of the rubber isolated set up of the clamp on hub. Kinda wonder if the electric motor kits out there use the same chain as the gas motor...would make for a clean install on one of those as well.
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
