These first pictures are the remains after I looked at the rear suspension and the parts that were left after changing the shock the original spring at my weight of 75kg works ok but the wheel was rubbing on the air box so I decided to put a longer shock I had to adjust the mounts but it was cheap and has a longer stroke and is thicker and that changes things because it works in a different amount of oil and oil is very important if you change the oil in the old shock absorber it will run better, but it is an expensive oil in the new shock absorber the spring was too hard and the bike did not bend at all I ordered a 350 pounds spring and it turned out to be too small original is at least 400 pounds so I installed the old spring in the longer shock absorber, changed the oil in it, loosened it to the maximum and it is great now only need to change the front oil, because the factory one is of low quality.
https://www.aliexpress.com/item/1005...martRedirect=y https://www.aliexpress.com/item/1005...21ef1c24SLqRv5
