Originally Posted by wheelbender6
The reason I am horning in on your thread is because I may buy a Genuine G400C, and it has Delphi EFI.
I’d like to own an RX4, but the seat height concerns me since I have only a 29” inseam. I ride in a lot of stop and go traffic and tall seats make that more difficult.
I own a 2021 RX4 and I lowered it 2" front and rear super easily
1.) i took out all the pre load and ran the nuts up to the top of the shock in the rear and locked them there... that dropped the rear almost exactly 2" (EDIT# I discovered that this is not the thing to do as it bottoms out the rear shock. I made a longer lower link instead to get it 2.5" lower)
2.) I loosened up the pinch bolts and raised the fork tubes in the triple trees up 2" and that lowered the front.... However to do that I had to buy some handle bar risers to fit the handle bars and move the handle bars back away from the fork tubes.... i got the 2" riser type that pivot in the original handle bar clamps
it worked real good I have a 30" inseam and can flat foot both feet at a stop.
Bob.....
