Old 04-21-2022, 12:32 PM   #9
The Delphi ECU is used on many small engines. They probably have similar (if not identical) sensors but the actual map is going to be modified to work with the specific engine model, exhaust and intake setup. As a purely academic exercise I'd like to know how the various sensors feed into the base map and how they interact. Check the throttle body size for that Genuine 400. On the RX4 it's a 45mm TB.
