Originally Posted by Cydrik
I will try this when I get home from work today. Do you have any guesses why my low and high beam does not work either? The daytime running light strip in the middle of the headlight works, but when I press on the low beams button, nothing happens; same with the high beams. However, the high beam flasher button works fine.
Ugh, this has been nothing but a hassle since I received this motorcycle and I haven't even been able to ride it yet.
Is the bike running when you test the headlights? The headlight only turns on when the bike is running.
As for the turn signal, just test the light to find out. To test my LED lights, I normally just test it on a battery using jumper wires.
