I guess I never considered the level issue with the valves installed with a spacer before. Funny enough, 220ml is about what I generally run in my forks anyway, so I guess it just worked out by chance. As long as the top of the valve is covered at full extension, it should work just fine though. As the bike sags and the forks compress from just being under its own weight or with the rider the level will come up anyway.
