New brushes arrived today so wrestled those in, was a bit of a fight as there are no locking pin holes or anything to keep the brushes back when you push the commutator in between but managed after a few tries, none of the springs didn`t even fly off once so that`s a win. Decided to grease the far end brass bearing with Wurth high temp grease so that I first heated the endcup as hot as my hand can manage then dropped in the dollop and applied pressure with the rotor axel so as to saturate the brass bushing or so I was told to do, not sure if it did a thing but seems to be turning fine now.
And that`s what almost 200 saved euros look like, wasn`t really broken just needed some long overdue TLC.
