Originally Posted by DualSportDude
It may have been on it's side during shipping, look for oil or fuel in the airbox. That happened to mine. Also You should call CSC they helped me and my buddy with issues when they first arrived. His had a vacuum line reversed that created a vacuum in the tank so the fuel wouldn't flow. Try starting with the fuel cap cracked to see if it's the vacuum line issue. But CSC will definitely help you get it going.
Agree. I know he got it started, but the lines that are reversed on some go to the charcoal canister that sits in front of the engine. The canister is marked, so it’s easy to verify. Mine would die after a few miles and the issue didn’t happen on the first few rides for some reason. CSC was very helpful. 500 miles and no issues since. Highly recommend the jet kit and the 47 tooth sprocket.
