Old 10-19-2021, 10:26 PM   #6
It looks like the Vulcan S comes with the same 15/46 sprockets. Did you have any issues with clearance with the 16 tooth? A 43 tooth rear would be about the same gear ratio with the 15 tooth front.
Nope, no issues. The chain is long enough to accommodate it without messing with any links. It seems like everyone was changing the front on the Versys...well, almost everyone. The wheely guys like the 15T. Some even go down to a 14T.
BTW, a 16T is the largest you can go on the front as it comes with a 520 chain. The best way to get the sprocket off is with an impact. For some reason they are super tight from the factory. There's a locking washer that needs to be flattened before accessing the nut.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
