Old 08-10-2021, 07:40 PM   #25
Lukas   Lukas is offline
If you want to download the bin. file injection maps or upload the new one you do everything as before but do not start the motorcycle engine , do everything with the engine turned off and do not press the connect button, the program will connect itself when you press the download button, the same will happen when you want to upload the bin file remember to always upload only the calibration table area, if you upload the tables and software, and something goes wrong ECU turns into a brick it can be saved, but it is better to avoid such a situation.
