I saw a video recently where someone tested the orange and blue CDIs and found that all they did was set the advance to the max (~20 something degrees) right at start up. The max advance was the same as the stock CDI. Having that much advance may cause hard starting. However, if your original CDI had a rev limiter, the "performance" ones do away with it so that's an upgrade.
