Originally Posted by pyoungbl
I have tried, twice, to get compatible levers from China. Although they were listed as fitting the RX3 and RX4 the clutch side really did not fit. It was more than just the clutch switch, I can shim that as mentioned. The perch itself did not marry up with the bracket on the handlebar. It was close but just not cut with the correct angles to work correctly. For $25 it was worth trying. Now I have two sets...anyone want to see if they fit your bike better than mine?
Peter Y.
So about the clutch issue, is it that the stock clutch cant be adjusted well enough by using the spinner adjustment?
From what i read it seems to be a comfort issue where the clutch engages very close to the start of the pull, is that correct?
Also.. the stock rear shock. im 175lb, do you think it will be too stiff for me? If so, can it be adjusted by clicks to make it softer?
