I would do away with the remote. Engine is fine. Just spec the valve clearance be done at the factory. Add a 6th gear but not at the same ratio as the 5th in there now. Like a slight overdrive. No FI. Too many things to go wrong. Oring chain. Analog gauges. USB port(s). Charging system to handle anything we want to add.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
