New to all this. Bought a 2020 Brozz a couple of weeks ago. Been learning/riding on my personal property as I have no license yet. Odometer only reads 30 miles. Taking a class in December.
Chain was messy with mud and plant material. Cleaned with kerosene, oiled with Lucas 80w90.
Adjusted valve lashings to .003 in. There was no clearance from the factory. Hoping I did it right because it's pretty clicky now. "Seems" to run better I think. Don't really know because I've never taken it on the road.
Set the drive chain properly. It was too loose. This was the most annoying job.
I started the engine when I had it off the ground, I wanted to see it "idle" in 1st. Noticed that when I pulled the clutch the rear wheel would still keep spinning from the engine's power. So I adjusted the clutch cable as per a video I found on YouTube and it seems to be doing OK. (For those wondering since I'm new; no I didn't clean/lube the chain with the motor on.)
Then I rode it around the woods for about 20 minutes but then it started sprinkling :(
Reason: Wording and spacing
