Originally Posted by JerryHawk250
Get a good LED bulb. It will be brighter and put out way less heat than a standard bulb.
I was quickly looking thru Amazon for 9003 LED bulb that was 35 watts or less. Most of the listed are 55 to 60 watts or wattage not listed.
I am also concerned about size of bulb. There is very little "behind the headlight" room.
Here is one that is listed as 35 Watts however size behind the bulb is a concern:
https://www.amazon.com/H4-9003-HB2-S...NsaWNrPXRydWU=
Thank you!
