Old 09-16-2020, 10:54 AM   #1
Falkon45's Avatar
KPM 200 Resource thread
PastorCZO:
Found a place for replacement parts
https://kpclubusa.com/collections/kpm-200
Okay, since the KPM 200 (LF200-3B) basically has an updated version of the NBf-2, and is a fairly new model, I decided to compile a resource list. Basically, instead of searching through my poorly named thread that most newcomers won't associate with what I'm doing, I'll make this one more appropriate.
Anyway, with everything I've found so far, Here's what's what.
Exhaust:
I have confirmed that the KPMOTO-Club exhaust works on this bike. It's kinda tight, but not hard to install. Just don't be afraid to force a few things here and there.
https://www.amazon.com/exec/obidos/A...im/refuge08-20
https://photos.app.goo.gl/inAND72b25C89mi48
https://photos.app.goo.gl/JfMxkxuEC9qkndKVA
Engine:
So, as I've stated before, the engine comes with two oil strainers. A coarse and fine strainer. But, if you don't think that's enough, I have found oil filters that may work: Fram ch6015-04
K&N KN-112 (confirmed fitment 3-12-2021)
Oil filter cross reference:
https://www.oilfilter-crossreference...rt/fram/ch6015
I haven't tested them yet, but I have 637 miles on the bike as of now. At 1200, I'll pop in the filter, and at 2400, I'll take it out and compare the first two oil change pictures. I'll also try and note any problems or power loss/gains I'm currently using Mobil 1 4T racing 10w-40. I'll use that same oil for the filter to strainer comparisons, then I'll switch to Castol 10w-50 4T
Here's some pictures of the oil change, and filters that could possibly work. In the filter pictures, the KN-131 is just there for size comparison.
https://photos.app.goo.gl/z3k1FxixEXpvHcJh8
https://photos.app.goo.gl/fC5YusCp8xQRUDyu9
K&N KN-112 filter install :
Also, the engine did come with a Magnetic Drain plug, so no need to go looking for one, unless you just want a different color, or aluminum.
Suspension:
Ok, these DO NOT come with a shock tool. You'll have to find one on your own.
Edit: I've found that the ER32 sized shock tool works. Here's the multi set I bought
https://www.amazon.com/dp/B08KD6RF8N...ing=UTF8&psc=1
The shock is pre-load adjustable and a two piece progressive spring setup. The fork is not adjustable. I really wish they'd fix the wording on that, because they make it sound like the fork is adjustable also. For us heavier guys, even with the pre-load maxed out, we'll still have too much sag. I'm trying to find measurements on the shock so I can see what can be removed from other bikes to fit, or for what size you will need for aftermarket shocks. I'll post links to any adjustment tools I find that can work.
For the swingarm spools, they take M8 or 8MM spools. These are readily available just about everywhere.
(NOTE: It seems as if the scrambler tires are no longer sold. The chinese market bikes may no longer be sold as scramblers anymore, and are more inline with what we get. tire links no longer work.)
Tire sizes are 100/80/17 front and 130/70/17 rear. These are CST tires, and I have found the scrambler replacement tires here:
/_yoycart_com/Product/625795363910
/_yoycart_com/Product/625795599556
The spoked wheels, if you want them, are here too:
https://www.yoycart.com/Product/615123023887/
I've not found the street tires the American bikes get. I'll be stepping up to 110/70/17 and 140/70/17 bridgestone S20 tires, but I was able to find the original tire size at Motosport.com and Revzilla.com.
Brakes:
FA197HH front and FA629HH rear. The front brakes are for a ninja 300, so any Ninja 300 pads should work. The rears are for a Grom, so there's a good place to look also.
Miscellaneous:
Rear racks, backrests, shifter and brake levers, and all kinds of goodies are found under this search.
https://www.yoycart.com/Search?Searc...00&catId=0&p=1
https://www.yoycart.com/Search?Searc...00&catId=0&p=1 UPDATE: Updated search results for yoyocart
If you want a more cafe racer look:
https://www.yoycart.com/Product/616455251080/
This list will be updated as more things are figured out.
Please feel free to add any information you have to it also.
Last edited by Falkon45; 01-11-2022 at 09:14 AM. Reason: 6/4/21 Updated search results
