Old 06-09-2020, 01:50 PM   #198
Raptorix   Raptorix is offline
Exclamation
I just finished HUD ECU Hacker version 1.5
I added the last feature that was missing: Data Slewing.
This allows to manipulate some of the values in the ECU.
These changes are temporary with the purpose of testing a defective engine.
Now HUD ECU Hacker replaces PCHUD by 100%.
Please read the completely rewritten documentation.
I added an ELM327 Terminal where you can test your ELM327 adapter for commands which are not working in most chinese adaptes.
I also added an Echo Test which allows to test chinese USB to RS232 adapters of which some are so buggy that they send wrong data.
_________________________
@ifstewart:
One question for you: You wrote that you have a Tactrix Open Port.
I only tested with my original Tactrix adapter which was very expensive. It works perfectly. My question:
Do you have a genuine or a chinese counterfeit Tactrix adapter?
In case you have a chinese how much did it cost?
Can you please test if it works and give me a feedback?
I have found so many problems with chinese ELM327 clones which are simply crap, that I want to know if at least the chinese Tactrix clones are working.
