Possible Coolant Leak
So now the question - where did it go? Do you have an external leak, such as a loose clamp, hole in one of the radiators, or a pinhole in a hose; or is it internal? Internal leaks would be a bad water pump seal or a bad head gasket, possibly a cracked cylinder head. If the bike is running fine, from an engine power standpoint, then it is most likely an external leak, somewhere.
