The engine is a zongshen ,depending on if it’s an older model or newer model it would have either Showa suspension ,or fast ace ,although they are the bottom of the line stuff from either company ,but it’s possible they would be able to get you parts to rebuild what you have .There is a member on this site ,that is a gio dealer ,his name is flashlightboy ,he can help you with parts if you don’t want to search yourself .
As far as I know ,the wheels should be a direct swap as the same bike was also sold with the larger wheels ,but I have not done that myself ,and I haven’t compared the bikes side by side so do some more research .
Finally ,I do like those bikes ,they really were very good for the money ,but if you are planning on doing all the work you listed ,I would not bother fixing the bike as the cost will be more than the bike is worth ,although if you can locate a donor bike it would be worth looking into .I know you didn’t ask that ,but I call em like I see em .
