Old 09-26-2019, 11:03 PM   #1
NzBrakelathes's Avatar
Originally Posted by sandog View Post
I got mine sorted out tonight. I backed out the air fuel screw 1 1/2 turns and it was still not wanting to run unless the choke was on.
Took the choke off again (new carb has a slotted head screw) to get to the screw, backed it out another 1 1/2 turns, and turned the idle screw in a bit.
Finally, runs good with the choke off for once, revs good, and no popping when you let off.
I'm sure it still needs some fine tuning, but it runs now.
Going for a ride in the morning !
Best use the tool for the air screw - open till best idle and close off 1/8 turn.
It is adjustable for a reason and no 1 setting in correct for all.
