Sounds like the float needle is stuck open.... sometimes the actual float will get full of gas to and not be able to float. A hammer might not do it.
Check your oil so that no fuel got into the cylinder, past the rings, and into the crankcase... if the oil smells like gas change it. You can check the sight glass too... if its level is higher then normal you most likely have gas in your oil now.
