Old 09-12-2019, 12:22 AM   #3
NzBrakelathes's Avatar
Originally Posted by sandog View Post
I noticed the choke had been on halfway.
This evening I got off work a bit early, and filled the tank with fresh gas, and did an oil change. I went over all the bolts and found a few loose ones, air filter looked clean as new, saw the rubber battery strap was broken so I rigged up another. Chain tension was good.
I put the choke on halfway and it fired right up, after a minute I raised the choke lever so it was off
Choke off is lower the lever.
You are putting the choke ON by the looks
