Originally Posted by Deckard_Cain
We pack ours into the garage for winter, unused during those months. I fill the fuel tank and add some stabilizer, drain the carb float bowls and run them dry. Then remove batteries and place them in the basement in a cool, dry space connected to a battery tender.
Come spring, put battery back in, turn fuel on and fill carb, start ATV and then go through the rest of the maintenance checks- tire pressures, cables, lube chain and suspension, adjustments and check bolts- then ride.
What stabilizer do you use?
Do you find that the temperature drop combined with being parked on pavement for several months affects your tires?
