Old 08-02-2019, 09:28 PM   #12
dirtbkr188's Avatar
The only thing I could suggest to bench test it is with a piece of wood across the front and a small block of wood on the back where the primary gear goes, put it in a bench vise and slowly close the vise to compress the clutch springs. The whole basket should move inward, toward the back of the clutch. I'd want to take my time by slowly cranking the vise in, it probably won't go that far.
I'm inclined to believe that there is something missing on the shaft, not letting the clutch to be out far enough for the actuator arm "top hat" inside the cover, to push the basket in far enough to disengage.
Did you get my PM from earlier today?
